I am attempting to convert an mkv file to a BluRay format dvd without re-encoding, using the guide at http://brothers_grim.webs.com/bd/index.html. Everything seems to go well, but when I try to play the resulting dvd in my player, a Sony BDP-S350, the picture is doubled horizontally, with the copy on the right in greyscale. The file info, as displayed by the player, says that the video is 1080p/60, but it is actually 720p/23.976. Is there an additional step I need to perform in order to get the player to recognize the correct resolution and framerate?
Here is the info for the original mkv file, as detected by MediaInfo:
Complete name : E:\Video\Movies\filename1.mkv
Format : Matroska
File size : 4.36 GiB
Duration : 1h 46mn
Overall bit rate : 5 883 Kbps
Movie name : filename
Encoded date : UTC 2007-05-30 19:08:47
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 45mn
Bit rate : 4 105 Kbps
Nominal bit rate : 4 370 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.246
Writing library : x264 core 54 svn-635M
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=hex / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4370 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:15.0
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 46mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Title : English
Language : English
Blu-ray players must have files that meet the spec. If you simply remuxed 1280x544 into a Blu-ray file many players won't play it. You need 1280x720.
1280x720 and profile 4.1main or lower read : https://www.videohelp.com/hd for a complete listing of specs
if all else fails read the manual
Converted MKV to Bluray-Seems no different?
By Ziani in forum Authoring (Blu-ray)Replies: 9Last Post: 4th Nov 2012, 15:31 -
my converted MKV to Bluray is not workin
By obadvw in forum Authoring (Blu-ray)Replies: 5Last Post: 30th Oct 2011, 03:18 -
MKV file displaying wrong aspect ratio on Bluray player.
By djfonti in forum Video ConversionReplies: 11Last Post: 5th Sep 2011, 21:05 -
playing dvd converted to mkv on bluray
By bkstaff in forum Video ConversionReplies: 2Last Post: 5th Jun 2011, 20:59 -
Using tsmuxer to convert mkv to bluray and the aspect is squished.
By heckybaby in forum Authoring (Blu-ray)Replies: 8Last Post: 9th Jun 2010, 09:07
