Results 1 to 21 of 21
    Jun 2004
    What's a simple, easy to use cd ripper. One that has a great output quality.
    With the latest LAME encoder update. I've been using WMP because it has the best info grabber.
  2. Member olyteddy's Avatar
    Dec 2005
    CDEx is my fave.
  3. CDex for simple ripper, EAC for scratched discs nothing else will rip.
    Pull! Bang! Darn!
  4. Member MysticE's Avatar
    Nov 2003
    Originally Posted by olyteddy
    CDEx is my fave.
    Using the LAME 'preset standard' setting (VBR).
  5. Member olyteddy's Avatar
    Dec 2005
    I use 96 to 256 kbs VBR. Usually averages out to about 210 kbps.
    Jun 2004
    I've always used CBR, is VBR a better setting?
    Jul 2001
    Jason,
    The only time you really need CBR is when trying to sync audio to video. Just makes it easier for editing/encoding tools in general.
    However, for simple audio/music, using VBR will help keep the file size small - which is why you're using MP3 in the first place - while allocating the bitrate where needed. Same principle as VBR for video.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    Dec 2006
    Here,where do you think?
    Yeah, CDex for simple ripping, EAC or dBpowerAmp for archiving ( think out of the box) to Flac-->foobar2k for MP3 -V 2 ~ 192 kbit/s and or AAC/m4a for my portables...
    And yes CDex rips to Flac as well.....Different strokes for different folks...
    " Who needs Google, my wife knows everything"
    Jun 2004
    Is there anything better than the latest version of LAME?
    As far as encoding.
  10. Originally Posted by jason
    As far as encoding.
    WMP 11 uses the Fraunhofer codec,they invented the format.I still think LAME(3.96 or better) does a better job at low bitrates.
    I always use CBR for player compatibility,my home and car stereo have problems with VBR.
    Jun 2004
    I was wondering what WMP used for encoding. It use to be Xing. I guess they switched it up.
  12. Member Seeker47's Avatar
    Jul 2005
    I like EAC a lot also. Gets the "between tracks" part right as well, thanks to the cue sheet feature. Before I started using EAC, the beginning / ending of many tracks would be incorrect.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  13. Member Seeker47's Avatar
    Jul 2005
    Jun 2004
    Is there a CD ripper that allows you to go in and change the LAME codec with the latest update?
    Feb 2004
    Pleasant Hill, CA
    In EAC, all you're doing is pointing it to where you have LAME located on your computer (it's not "built-in"), so you can use whatever version of LAME you want to use.
  16. Originally Posted by jason
    CDex also allows you to update,just drop the lame_enc.dll file into the CDex folder.
  17. Member olyteddy's Avatar
    Dec 2005
    The $15 (Pro) version of WinAmp uses the Fraunhofer encoder too. It also uses CDDB and Gracenote as the data bases.
  18. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Fairstars CD Ripper (Has most of the codecs included) and Audiograbber (needs LAME), just drop the latest LAME into the appropriate directory.
    Jun 2004
    Thank you for the help.
    Jun 2004
    Winamp uses the latest codecs, they have LAME3.98.2 and the latest Fraunhofer. They seem to update more than WMP.
