I'm using DVDAuthor with a basic XML config file and would like to add the following pre command which I'm currently configuring using IfoEdit after dvdauthor has completed. I would like to add this to the dvdauthor XML file to remove the IfoEdit step but I'm struggling with the syntax of the pre command and just get an error. can anybody point me in the right direction I've been hunting for an answer but have found nothing so far.
(SetSTN) Set Subpicture Stream: 31(Off)
Whilst composing this post I discovered the correct syntax on the DVDAuthor man page see the following, my problem was that I was trying to use "off" when in actual fact it wasn't needed. I thought I would post this anyway since I struggled to find info on this issue.
<dvdauthor dest="z:\Final">
<vmgm />
<titleset>
<titles>
<video/>
<pgc>
<pre>subtitle=31;</pre>
<vob file="z:\2008-11-16.mpg" chapters="0,0:05:0"/>
</pgc>
</titles>
</titleset>
</dvdauthor>
Results 1 to 1 of 1
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 7Last Post: 15th Jun 2015, 17:08 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
Changing menu command No Subtitles to subtitle 3?
By ericf in forum Authoring (DVD)Replies: 6Last Post: 3rd Apr 2009, 00:28 -
Command line syntax for mp4box?
By freebird73717 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2008, 21:57 -
Automatically creating pngs for DVDAuthor Subtitle MPGs
By tacman1123 in forum Authoring (DVD)Replies: 8Last Post: 5th Jun 2008, 09:15
