Hi,
New to this site hence me using this forum with my question. Inadvertantly I bought a couple of DVD's which were region 1, not 2, before I left the UK for Spain. On arrival I found that my original player broken. I've just bought a Sivercrest KH 6779 from Lidl's but need to reconfigure my DVD for all regions. Can anyone please help????
Cheers eaglet
	You should have searched for a player that you can reconfigure BEFORE you bought a new player.
 Not all players can be reconfigured or hacked region free/all region.
	It's getting more difficult all the time to find DVD players that can be made region free. Hollywood has somehow apparently convinced almost all the manufacturers to stop making players that can be made region free. This is pure insanity because it will surely lead to more piracy since people will no longer have the option of buying DVDs outside of their region, but somehow Hollywood is convinced that refusing to allow people to change the region coding on their players is a good thing. Philips used to make DVD players that could easily be put into multi-region mode, but I'm not sure if they make any such players now.
 Anyway, you might consider ripping the DVDs to your hard drive and re-burning them. Ripping will remove the region coding. As long as your DVD player can do something with NTSC TV signals that your TV will accept (the odds are very good you'll be OK here since you live in Europe) this is an option. We have some guides on ripping and burning that might be of use to you. Usually European TVs and DVD players can display NTSC signals correctly, so there probably is no need for you to convert the DVDs from NTSC for PAL.
  Various Regions PAL DVD'sBy dblan9 in forum Authoring (DVD)Replies: 6Last Post: 11th Mar 2010, 18:10
  Toshiba SD K860 regions codeBy zork152 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Apr 2008, 18:13
  Data DVD Regions?By cyberdrugi in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 15:06
  XBox 360 HD Drive and HD-dvd - regions?By elfranko in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Nov 2007, 12:15
  How to change regions on a DVD or TV?By SnowStormWolf in forum ProgrammingReplies: 1Last Post: 8th Jul 2007, 18:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
