Hi all,
I
m converting vob dvd rips to wmv via tpmpeg, im making them 1.4gb from their orignal size,,ive set the resalution the same as input @ 720x576 and aspest ratio 1:1 square pixal (which i would asume is the same as the input) but the output seems to have much larger black bars and the video a bit squashed looking when i play it back from my pc,, if the video is 16:9 iv even tried setting the aspect ratio from 1:1 square pixal to 16:9 but it doesnt seem to help.hope you can help as i have a rake load of dvds that i want to put to hdd and want to do it right the first time.
Thanks,
Eao.
I thought they spoke English in Ireland.
You can set a PAR in the encoder (don't know about TMPGEnc, though) so that the player does the resizing (and not all will do it), or (as I would recommend) resize it yourself to some real 1:1 ratio such as 624x352 (assuming a 16:9 DVD). If cropping away the black bars then the final resolution will most likely change....ive set the resalution the same as input @ 720x576 and aspest ratio 1:1 square pixal
Why anyone would purposely encode for WMV is beyond me. -
ok well il use the resalution you suggested, will the picture be worse as the resalution is smaller , i was converting to wmv so i could stream to an xbox aswell,if not wmv what format would you suggest and why,no doubt i will take your advice as i dont know much bout this stuff.and as iv said i only want to do it once.
thanks alot for the reply. -
Worse than all the people being too tall and too thin and round things looking oval shaped? Make it a larger 1.78:1 ratio then. How about 1024x576? I don't know what formats X-Box accepts, so someone else will have to help with that.will the picture be worse as the resalution is smaller
I'd try 720x400. That's about 16:9 with square pixels and won't require resizing on the horizontal dimension.
WMV is perfect for the xbox 360.Originally Posted by eao1
It can do mp4 but it is very very picky about what types of mp4 it does.
Of course if you use something like tversity to stream to the xbox than you can encode pretty much to anything you want and the media server will transcode it to something the 360 can handle.
Just remember a wired lan connection is best for streaming video. WIFI G isn't practical. N may work well but I don't know if they make a xbox 360 compatible wireless N adapter yet or not.
EDIT - @ MANOMANO - I encode all the time to wmv for use on my zune. It works just fine. I wouldn't knock a format just because you don't personally use it. There is usually a use for something even if it might not be the latest craze.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
yep i encoded at 720 x 404 much better thanks,i know bout tversity and even tried it with my 2.5 ghz amd quad core but still manages to buffer half way through a 1080p mkv bloody disgraceful if u ask me and thats on a wired network, i have a load of vob movies sd that are ot watched much really and want to save some space but still have them in reach for xbox and pc playback with decent quality and with tmpeg at quality 100% and resolution set to 720 x 404 wma pro 5.1 you cant even notice the difference, thanks for all the help guys its appreciated,
eao1.
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 06:53 -
how to correctly crop mantaining aspect ratio.
By Pepepaco in forum Authoring (DVD)Replies: 10Last Post: 15th Jul 2012, 18:49 -
Changing aspect ratio for WMV?
By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 09:27 -
VOB Aspect Ratio
By Lt. Dang in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 18:17 -
Changing Aspect Ratio on wmv to divx conversion.
By steve_hawthorn in forum Video ConversionReplies: 7Last Post: 27th Feb 2008, 12:58
