Hello,
I am converting a few movies. They are in the vob format with the VIDEO_TS folder.
- I would like to keep good quality even if not reducing the size so much.
- And if possible to be able to read them on a play station 3.
Could someone, please, give me some advice?
1. Which format should I use?
MP4, M4V, MKP, AVI or OGM
2. Which video codec should I use?
H.264, MPEG-4(FFmpeg) or MPEG-4(XviD)
3. What Frame Rate should I use?
Same As Source?
4. I am using Two-Pass encoding. Is this the best way?
5. On quality should I define a Target Size (MB), an Avg BitRate (kbps) or Constant Quality (%)?
6. On sound should I use:
AAC, MP3, Vorbis or AC3?
Stereo, Dolby Surround or Dolby Pro Logic II?
And what about the bit rate?
I've created a basic definition but I really would like some advice.
Thank You,
Miguel
Hi,
I am planning to buy the following:
http://www.westerndigital.com/en/products/products.asp?driveid=572&language=en
But just in case I am considering a format that would be also playable also in Play Station 3:
http://manuals.playstation.net/document/en/ps3/current/video/filetypes.html
I am using the following encoder:
http://handbrake.fr/
REVIEW: http://www.metacafe.com/watch/2096881/handbrake_dvd_ripping_software_review/
I would like to use H.264 since it seems to have a better quality ... Or not?
And use the file format MKV since I think it is possible to play in ITunes and many others and supports H.264 ...
I would like advice on two situations:
1. Care about PlayStation 3 compatibility
2. Not care about PlayStation 3 compatibility
Thanks,
Miguel
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
