Hi, I 've got the Panasonic SDR-S7. I like it's 16:9 resolution, but I am a bit confused with its (camera's) resolutions. What is the original resolution for 16:9? 768x432? I 'd like to know which resolution to use in order to convert the clips to avi. I open original .MOD files with MediaInfo and it says 704x576(16/9). When I place the clips on divx converter it says 720x400. Is it standard for 16:9 clips their width to be 1.77x their height? Please if you know what is the native resolution of both 4:3 and 16:9 so as to use these on conversion without upscaling or downscaling. TV system of my camera is PAL. Also this camera demonstrates "DVD Quality recording". Thanks.
dvd widescreen uses non--square pixels to make use of the 704x576 recorded size. multiply 576 by 16 and divide by 9 to get the equivalent size in square pixels. or 1024x576.
Preserving image quality from flash camcorder to dvd?
By rsud in forum Authoring (DVD)Replies: 7Last Post: 19th May 2010, 17:57 -
Poor DVD Quality - Camcorder to imovie08 to iDVD
By Karl K in forum MacReplies: 12Last Post: 28th Apr 2008, 22:53 -
Help on how to convert HDTV to DVD Resolution for the best quality
By Kid Chameleon in forum DVB / IPTVReplies: 62Last Post: 5th Apr 2008, 07:31 -
Panasonic VDR-D100 DVD Camcorder for mac
By crocker5731 in forum MacReplies: 9Last Post: 29th Sep 2007, 22:11 -
Is a Panasonic VDR-D100 DVD Camcorder?
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 12th Sep 2007, 20:40
