  1. Anonymous
    Guest
    I've encoded to they 2 folder outputs.can i just plain these as files on a dvd and have it work in a player or do these have to be used in conjunction with other software the adds the dvd(sturucture) component?
  2. Member MourningStar's Avatar
    Mar 2009
    Just pop it in a dvd player and enjoy!
  3. Member Number Six's Avatar
    Mar 2008
    Does the VIDEO_TS folder have IFO, BUP, and VOB files - if so, then it would play. If it does not have all these files, it needs to be authored to DVD.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
