I recently tried to capture my Sony analogue V-8 camcorder tape to .avi file to my pc, however, I noticed the size of the .avi file is so big such that in average 1 GB for a minute.
eg. 30 minutes has 30 GB .avi file when I capture in the resolution: 720x576
Any idea how come so big?
because you are compressing with either no compression (i.e. Uncompressed), or using a lossless compression such as Lagarith or Huffyuv.
What did you capture it with ? - what sort of card ?
What do you intend to do with the video ?
Some cards can capture to mpeg-2 directly. If you are going to DVD then this might be an option. if you want to edit then either capture at a high bitrate (15 MB/s) or capture using the DV codec.Read my blog here.
~60 GB/hr is probably uncompressed YUY2 or other YUV 4:2:2 subsampling. A lossless encoder like HuffYUV will get down to about 1/2 to 1/3 of that without losing anything. MJPEG can get you lower (you can choose how much you want to compress) but image quality will suffer if you get too low. A DV codec will be a fair compromise of quality vs file size. About 13 GB/hr.
I looked at HuffYUV website:
Huffyuv is intended to replace uncompressed YUV as a video capture format. It is fast enough to compress full-resolution CCIR 601 video (720 x 480 x 30fps) in real time as it's captured on my machine.
It handles the 720x480.
How about if I set to 720x576?
Do you think any significant loss if I capture in 720x480?
The reason I capture from my analogue to my pc was I want to make a back up of my family video. You know no one knows when my analogue camcorder will die very soon. -
Hi, the capture device I am using is called "EasyCAP". This is a external analogue-to-USB device.Originally Posted by jagabo
HuffYUV can compress frames of any even (as in even vs odd numbers) resolution. The capture card should tell HuffYUV what the frame size is (720x576 in your case) and HuffYUV shouldn't change it.Originally Posted by ManUtdFans
Hi, do you think there is really a significant different in the video quality between
720x480 and
720 x 576 ? -
It's not a matter of quality. NTSC video is broadcast as 480 scan lines. PAL video is broadcast as 576 scan lines. If you somehow manage to capture 480 scan lines of a PAL broadcast (most capture programs wouldn't even allow this) you will be missing 96 scan lines, about 17 percent of the frame.
Convert analogue camcorder tape to pc
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 22:59 -
Dumb Question - How Big Is 1 Minute Of Blu-Ray?
By hech54 in forum Newbie / General discussionsReplies: 12Last Post: 14th Dec 2009, 16:10 -
.FLV for 10 minute video way too big
By Pureweb in forum Video Streaming DownloadingReplies: 48Last Post: 28th Mar 2009, 05:53 -
Question about converting 174 minute DVD movie to 700mb avi
By jimdagys in forum DVD RippingReplies: 8Last Post: 7th Mar 2009, 04:18 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29
