Hi, is there any hauppauge card that currently supports PAL input from analog (coax)? Im planning to buy a PVR-150 card, but there are mixed opinions about this card.. One says that I can registry patch to enable my card to use PAL (even if I have a NTSC model) and other says that I need a PVR-150 PAL model.
So, witch card should I choose? I tried searching online for a PAL card in the US (amazon and ebay) but I cant find one
Any help or other hauppauge card suggestions are really appreciated
				Results 1 to 10 of 10
	As far as I know Hauppauge sells separate cards to NTSC and PAL markets. You should call and ask if they have a PAL-M model for Brazil. Check to see if there is a Brazil distributor. US cards will not decode PAL-M and will display as noisy monochrome. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I tried looking for a hauppauge card here in brazil but no luck ;/
 Does anyone recommend a place I can buy a PAL Hauppauge card in the US?
	They don't sell PAL cards in the USA.Originally Posted by TioSolid
 Their PAL cards would be for Euro PAL (50Hz, 4.43MHz subcarier) so would not work for PAL-M (60Hz, 3.58 subcarrier).Recommends: Kiva.org - Loans that change lives.
	Thanks for your reply. But wouldn´t be possible for a NTSC card to decode a PAL stream using some kind of software?
	No. Hauppauge does this on purpose. They want to separate marketing regions.Originally Posted by TioSolid
 PAL-M is a unique standard in the world.
 It is possible to use a device like the HD-PVR with a separate PAL-M decoder where the connection is analog component YPbPr. If your TV or cable set top box exports decoded analog component YPbPr, then there is no difference NTSC vs. PAL.
 http://www.hauppauge.com/site/products/data_hdpvr.htmlRecommends: Kiva.org - Loans that change lives.
	Well, the unique solution I have right now is paying for cable TV since it set-up-box comes with a component output and I can either select PAL or NTSC for that.
 Is there any other brand I can choose that support PAL, is not shitty like the Pixelview cards and can be bought in the US?
	If the cable box converts PAL-M to NTSC, then any composite or S-Video NTSC product should work. Why then convert from PAL-M? I don't understand what you want to do.Originally Posted by TioSolidRecommends: Kiva.org - Loans that change lives.
	Its because our air TV (open) is PAL-M
 Im planning to use cable TV soon, but having support for air TV is a must since if I cancel my contract with the cable provider my tv-card will become useless.
	Well then you should look to domestic Brazil solutions. Some older simple BrookeTree (BT) based tuner/capture cards support PAL-M but those are less available here since we are converting to all digital broadcast. You will find those older cards in the used market.Originally Posted by TioSolidRecommends: Kiva.org - Loans that change lives.
  Hauppauge PVR recognizes component input source from blu ray as 720x480By dbeauchamp in forum Blu-ray RippingReplies: 3Last Post: 1st Oct 2011, 23:26
  Analog Video Capture Hauppauge 1600By jrtmouse in forum Capturing and VCRReplies: 6Last Post: 13th Aug 2010, 15:46
  Portable PAL analog (yes, analog!) television setBy stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 20:23
  Hauppauge HVR-1800 Composite input - NO AUDIOBy jhg in forum Capturing and VCRReplies: 8Last Post: 1st Jul 2008, 17:20
  How do I setup my Hauppauge to record what's in the composite input?By RoganSarine in forum Capturing and VCRReplies: 4Last Post: 18th Dec 2007, 00:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
