Hi all
Why these movies did NOT work fine in my (WD TV HD Media Player)
it show me like this:
see attachment for info about these movies did NOT works fine
mov%20not%20work%20fine.rar
Closed Thread
Results 1 to 9 of 9
Now these info file about movies that works fine with me !
work%20fine.rar
You have too many reference frames (16)
For 1920x1080 you usually use L4.1, max 3-4 ref frames for compatibility. Since you are using b-pyramids, you subtract 1, so stick with 3.
Just "changing the level" as in the header information 99.9% of the time does NOT work; you can try h264info if you want
You will likely have to re-encode (=lose quality). It will be better if you re did the encode from the orignal source.
Extract the h264 video using mkvtoolnix and then try edit it using h264info.
seem that H264info does not support MKV file !
when I press in input to open the file it show me nothing !
unfortunitly i do NOT have the orignal source because I downloade these video form RS links ,,
i/o error during transfer, that is the answer and when you got missing bits with an h264 video the result can be that awful.
I got two seagate drives that regularly produce i/o errors so i know what i'm talking about. (freeagent models)
I had some errors with my Wd hdd but very few so you should retransfert the vid.*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Digitising BD movies to play on media player
By khnguyen17 in forum Blu-ray RippingReplies: 6Last Post: 10th Mar 2012, 22:10 -
Subtitle not work with WDTV Media Player
By mmkk in forum SubtitleReplies: 4Last Post: 18th May 2010, 02:58 -
window media player does not work
By romanstopme in forum ComputerReplies: 8Last Post: 6th Dec 2008, 13:21 -
Cant Get Vista Media Center to Work Even with My Movies Plugin
By jet757f in forum Media Center PC / MediaCentersReplies: 18Last Post: 6th Jul 2008, 19:40 -
Windows Media Player 11...No Video but Sound?? It was working fine
By sandman423 in forum Software PlayingReplies: 2Last Post: 14th Jan 2008, 14:57
