How do I make a perfect 1:1 bit-to-bit copy of DVDs?
if you are referring to retail movies, it isn't possible at all. the css is written in an area only pressed dvds can write to.
Thanks for the reply guys.
I have another question that I don't want to create a new topic for.
In DVD Shrink, when I select "No Compression" will there be any loss in audio/video quality? -
As far as video and audio quality goes, YES!!
But then you did not originally ask if there was any quality loss, just if you could make a "bit for bit" copy.
But minidv2dvd is correct about the copy protection, but then who would want to copy/transfer that over 8)
& they don't "write" to pressed dvd's :P
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 17:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 11:12
