About a month ago, I upgraded to Windows XP. When I try to use my Television program that came with my ATI All in Wonder 128 card, it says that it cannot locate the correct drivers or something. I downloaded the display drivers and that did not solve the problem. It seems to me that ATI is not offering any drivers for XP for any version of MMC. SO, I downloaded the new version of MMC, and I tried to install it. The problem is that it wants me to uninstall my previous vision of MMC. Fine, BUT, when I try to uninstall it, it says:
"Unable to locate the installation log file 'C:\Program Files\ATI Multimedia\Uninst.isu’ Uninstallation will not continue."
Is there any way to fix this problem? And one more thing, how will MMC perform for capturing under XP. I haven't been able to try it out. Thanks.
OK you need to follow the guide in how to capture with the ATI AIW.
It will show you how to install thing right. ATI has drivers for XP. I use MMC 7.5. I have the ATI AIW 128 pro AGP 32meg with XP. I can capture
just fine. You will also might want to disable the macrovision on the AIW too.
Look for capturing avi with ATI all in wonder
these steps came directly from Ati (hope it's help )
In regards to the installation/configuration of the All in Wonder Radeon.
First you should download and install the latest VIA 4in1 drivers for your motherboard. These are available from the URL below. Download the version 4.33 FINAL.
http://www.viahardware.com/download/index.shtm
I have included instructions below for you to properly remove and reinstall the ATI software and drivers. I would suggest using the latest ATI software available from the ATI web site. You can download the latest drivers, Multimedia Center 7.1 and DVD 4.1. You will also need to install the Video Capture Update for DirectX. This is available from the second URL.
http://support.ati.com/products/pc/radeon/radeon_drivers.html
http://www.microsoft.com/directx
Should you require any further information or assistance, do not hesitate to contact us again.
Please quote your ATI Customer Number
Regards,
Technical Support Canada
ATI Technologies, Inc.
http://www.ati.com for Sales/Marketing and Product Information
http://support.ati.com for Technical Support, Driver Download, FAQ's, etc.
1. remove the ATI Multimedia Center and Display driver
- go to add/remove programs in control panel
- remove the ATI MMC
- remove the ATI Display Driver
2. boot into safe mode
- tap F8 or Ctrl when system is booting
3. open Device Manager
- open Display Adapters section
- open Properties for ATI card
- Install "Standard VGA Driver"
- go to Driver tab > click Update Driver
- select the option "display a list" when it appears > click Next
- select "show all hardware"
- choose Standard display types > highlight Standard Display Adapter VGA
- follow through with the installation
- DO NOT RESTART
4. Run REGEDIT
- go to the RUN command > type REGEDIT > click OK
- find and remove the following entries if they appear
HKEY_CURRENT_USER > Software > ATI Technologies
HKEY_LOCAL_MACHINE > Software > ATI Technologies
HKEY_LOCAL_MACHINE> Software > InstalledOptions > ATI Technologies
- close the registry editor
5. Run "MSCONFIG"
- click START
- click RUN
- type MSCONFIG, press ENTER
- on the GENERAL TAB, click SELECTIVE SETUP, remove the check from:
- LOAD STARTUP GROUP ITEMS
- apply the changes
- RESTART into Normal mode
6. Install the ATI display driver
- should any Version Conflicts occur select NO
- when driver completes installation RESTART as prompted
7. Install the latest ATI Multimedia Center
- install the MMC and RESTART as prompted
8. Install the Video Capture Update for DirectX
- install the VCUpdate and RESTART as prompted
- VCUpdate is available from:
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
ATI ALL in WONDER 9600 TV & capturing problem
By ikeogut in forum Capturing and VCRReplies: 35Last Post: 31st Aug 2008, 05:51 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13 -
problem with the ati tv wonder pro pci card
By SabbathPwns in forum Capturing and VCRReplies: 0Last Post: 7th Jul 2007, 04:21
