Until recently I was using MediaPlayer Classic, version 6.4.9.1. But when I tried to take an occasional snapshot it would fail with the obscure error message "GetCurrentImage failed, hr = 8000ffff". I then followed a recommendation from SanderMan to try Media Player Classic Homecinema and that seemed to work OK. But I've just used it on a 16:9 movie clip and was disappointed to find that the resultant images were 720x576 (1.25:1). So far I haven't found any way to change that. Anyone know what's happening here please?
Terry, East Grinstead, UK
for mpc, it has to be using vmr7 or vmr9 (renderless) for renderer, you can find it in the options
it might also depend on what decoder you are using, e.g. using ffdshow for mpeg2 decoding, it displays anamorphic screenshots correctly
warning: using a different renderer will change the appearance compared to overlay mixer, eg. vmr9 renderless will make the luminance low and colors faded.
another option is to use kmplayer which can take screenshots "as you see", or the native frame size -
Thanks both, got it now,
BTW, sometimes (not consistently) I can get a capture with the PrtScr key.
Terry, East Grinstead, UK -
If the player is using the graphics card's Video Overlay feature Print Screen will give you a blank window.
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 07:30 -
Streaming FLV in WM Player or Media Player Classic
By jlz901 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2010, 11:09 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Media Player Classic and Windows Media Player 9.0
By siluet in forum Software PlayingReplies: 0Last Post: 26th Dec 2007, 10:01 -
Media Player Classic help
By gthorley in forum Software PlayingReplies: 1Last Post: 22nd Aug 2007, 16:04
