Hello,Its my second post,I have previously converted two complete season of "desperate housewives" Season1 and 3 into avi. I had decrypted the DVDs into hard disk using DVD decrypter then through AutoGK I've successfully converted into avi's.It's working just fine.
Now when I try to do the same for Season 2 DVDs,the avi file's audio/video is out of sync(maybe 2-3 seconds difference).Please help me with this.
Also: I've seen that in the "DVD Decrypter" window, The first VTS had 3 files(Episode+2),and the rest had 2 files(episode+1) each.while with s1 and s3 DVDs I've seen that the first VTS had two files and the rest had only 1 file each.Just to be clear.Pls help.
ive been a lurker for awhile on this site and recently i started ripping my dvds into avi format. i had great results with autoGK with a couple dvds but one was WAY out of sync with the sound. so i tried just about every program out there, and not just the free ones, and nothing worked at all. then i read this post and i saw you mention HandBrake and i just had to register and give my thanks to you because it worked. finally!! im so happy. thank you so much. HandBrake is very easy to use, i am a newbie and i had no problems..perfect results on my first try. so, if you guys run into a dvd that just wont rip to avi in sync then use HandBrake. here is my program list:
1. rip dvd with anydvd
2. extract main titles with clonedvd
3. mount iso image with virtual dvd drive
4. open and convert ifo with handbrake or autoGK
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 01:39 -
AutoGK- Audio Video completely out of Sync
By src2206 in forum Video ConversionReplies: 2Last Post: 8th Feb 2008, 11:49 -
Audio Sync Issue with AutoGK
By KaRRiLLioN in forum DVD RippingReplies: 5Last Post: 5th Feb 2008, 16:27 -
autogk, audio out of sync
By Disa in forum DVD RippingReplies: 2Last Post: 30th May 2007, 16:03 -
autoGK subtitle out-of-sync with audio?
By cristolin in forum SubtitleReplies: 0Last Post: 16th May 2007, 01:14
