I have some VOBs of a ripped DVD on my harddrive. Its a music DVD.
The DVD is separated into a number of chapters. Each chapter is 1 song.
But the VOB files does not match the chapters. So, I can not just rename the VOBs to MPG....
How can I extract the chapters without actually converting anything. I´m happy with the large file sizes and good DVD quality.
Please help!
Results 1 to 10 of 10
If you pay to register the latest version of VOB2MPG then you can extract by chapter. No encoding, just a repackaging from VOB to MPG.
If you want to do it for free you can use DVD Shrink in reauthor mode to output just a chapter at a time, then use the free VOB2MPG on each VOB that it creates.Read my blog here.
hech54: When I choose IFO mode, I can not choose directory (where they are) - I must choose the CD/DVD drive only.
Ah ok! Thanks!!
(Superb forum this. So very quick answers I almost dont have time to express my question until I get the answer in my face....
If the disk has been ripped to a folder (and you don't want to re-rip it), open the folder in DVD Shrink, output as an ISO.
Mount the ISO using (free) Virtual Clone Drive and use DVD Decrypter. -
If the entire DVD is on the hard drive and you want to extract the songs (=chapters=cells) out of it, use PGCDemux. Under Options check "Create a PGC VOB" and under Mode choose "Single Cell". Use the drop-down box to choose the cell you want. Each demuxed cell VOB should be a single song.
No need to decrypt it again; no need to make an ISO first. This assumes that you got the IFOs when decrypting, because you'll be opening the IFO for the VTS where these songs are located. -
How To Rip DVD To Separate Chapters?
By Nitro89 in forum DVD RippingReplies: 7Last Post: 14th Apr 2011, 12:06 -
Extract chapters from a DVD
By hcs in forum Authoring (DVD)Replies: 3Last Post: 8th Jun 2010, 05:50 -
Chapters extract for MKV
By jameson_uk in forum Blu-ray RippingReplies: 10Last Post: 28th Feb 2009, 12:35 -
43 Chapters to 11 Separate Files
By GrayStrickland in forum EditingReplies: 2Last Post: 19th May 2008, 19:15 -
[c++] vfw.h how to extract video stream into separate file?
By dreel in forum ProgrammingReplies: 0Last Post: 3rd Dec 2007, 17:57
