    Aug 2007
    Hello--
    I have been capturing some HD video (Discovery HD) using FireRecord. It works great, no complaints. However, it saves all the files in the .m2t format. I've been trying to use MPEG Streamclip to edit and convert/export the videos.
    This is where I am running into problems. At first I couldn't even get "Export to AVI" in menu to function at all--I kept getting compression errors after 30 seconds. After I acquired DivX Pro, the "Export to AVI" function now works better, but still wont complete. I get a compression error 5-20% in. I don't even know what the difference between "Export to AVI" and "Convert to MPEG with MP2 Audio", and how they affect my HD content. However, using "Convert to MPEG with MP2 Audio" with the .m2t file works fine (and is fast!--exporting to AVI is very slow).
    Also, I am attempting to convert the mpeg file from what I described on the line above to AVI in QuickTime now, and its going to take over an hour and a half (the clip is only 10min) while converting to mpeg from m2t only took 30sec. So basically I am a little lost. What should I convert my .m2t to if I want to keep a reasonable HD quality? (honestly i think the mpeg+mp2 looked better than the .avi but avi is the ideal size).
    Any advice would be appreciated.
    Aug 2005
    Palo Alto, California USA
    The short answer is: Don't convert if you want to preserve quality. Each transcoding introduces degradation.
    A file format conversion is not included in the advice above. Going from .m2t to "regular" mpeg just changes the file wrapper, not the video itself. That's why the conversion was fast, and also why the quality was the highest.
    If you want smaller file size, then understand that it can be done, but at the cost of reduced quality. If quality is the most important factor to you, then leave it as unmolested as possible, and live with the file size. Disks keep getting cheaper all the time, so don't let storage limitations constrain quality.
    Aug 2007
    ok, that makes sense. what if i want to get it down to the 350-500mb range while still maintaining quality that other people would want to watch it?
    heres some more info about what ive got---
    *** MediaInfo Mac // Plain text file report
    2009-03-26 09:08:35 -0500
    Information for File: untitled 004.m2t
    General / Container Stream # 1
    Total Video Streams for this File -> 1
    Total Audio Streams for this File -> 1
    Video Codecs Used -> MPEG-2 Video
    Audio Codecs Used -> AC3
    File Format -> MPEG-TS
    Play Time -> 59mn 58s
    Total File Size -> 4.58 GiB
    Total Stream BitRate -> 10.9 Mbps
    Video Stream # 1
    Codec (Human Name) -> MPEG Video
    Codec Profile -> Main@High
    Frame Width -> 1 920 pixels
    Frame Height -> 1 080 pixels
    Frame Rate -> 29.970 fps
    Total Frames -> 107853
    Display Aspect Ratio -> 16/9
    Video Standard -> Component
    Scan Type -> Interlaced
    Scan Order -> BFF
    Colorimetry -> 4:2:0
    QF (like Gordian Knot) -> 0.306
    Codec Settings (Matrix) -> Default
    Video Stream Length -> 59mn 58s 692ms
    Video Stream BitRate -> 10.1 Mbps
    Video Stream BitRate (Nominal) -> 19.0 Mbps
    Video Stream BitRate Mode -> CBR
    Audio Stream # 1
    Codec -> AC-3
    Audio Stream BitRate -> 384 Kbps
    Audio Stream BitRate Mode -> CBR
    Number of Audio Channels -> 6
    Audio Channel's Positions -> Front: L C R, Rear: L R, LFE
    Sampling Rate -> 48.0 KHz
    Audio Stream Delay -> 1h 10mn
    Audio Stream Language -> English
    My system:
    Mac Pro
    2x 2.66ghz dual core (quad core)
    9GB DDR2 RAM
    ATI X1900 XT
    OS X 10.5
    Aug 2007
    so ive found a few things
    im using avidemux2_qt4 2.4.4. it works great! cutting works fine. im working with a .m2t file thats around 5gb. cutting the beginning works, and the end. however, when i navigate to the middle of the video, the application continues to crash. this happens on any video that i attempt to edit. any ideas? could it be a memory issue?
    im running OS X 10.5.6
    heres the error from OS X
    Process: avidemux2_qt4 [2146]
    Path: /Applications/avidemux2_qt4.app/Contents/Resources/bin/avidemux2_qt4
    Identifier: avidemux2_qt4
    Version: ??? (???)
    Code Type: X86 (Native)
    Parent Process: bash [2130]
    Date/Time: 2009-03-26 12:09:45.901 -0500
    OS Version: Mac OS X 10.5.6 (9G55)
    Report Version: 6
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000200b7294
    Crashed Thread: 0
    Thread 0 Crashed:
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x200b7290 ebx: 0x00525fd9 ecx: 0x00000000 edx: 0x06032600
    edi: 0x060ad43d esi: 0x200b3510 ebp: 0x00000000 esp: 0xbfffbf20
    ss: 0x0000001f efl: 0x00200206 eip: 0x00526b42 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0xffe17d2c
