    Feb 2002
    Hello everyone,
    I am having some trouble capturing some footage using a Canon Elura 65 camcorder.
    The footage is on a miniDV tape, and was recorded using a Panasonic DVX-100. It may have been recorded in 16:9, although I'm not 100% sure. When I play it back on the Elura, there are black bars on the top and the bottom of the image, and the image is stretched out. When I try to import this into iMovie '09 (via Firewire) the image on the screen (matte black Macbook) is just like it is on the camera's LCD -- stretched out. I have tried to change the project's properties in iMovie to both 4x3 and 16x9, but that doesn't make a difference.
    Is there any way to unstretch the image? I feel that if the image is unstretched while playing back in the camera (Elura), it will be fine when importing back into iMovie. Otherwise, is there an easy/fast/good quality way of doing it once it's on the computer in iMovie?
    Thank you for any help
    Feb 2002
    UPDATE:
    When attaching the Canon up to the television (a standard 4x3 tube tv) via s-video, the footage was displayed perfectly (on the tv, still stretched on the camera's LCD). It was not stretched, in 16x9, with the appropriate black bars on top and bottom.
  3. capture the DVavi over firewire. play it back. if it has back bars and looks fine it is 16/9 recorded as 4:3 with permanent black bars. if it looks tall and narrow and has no black bars it is real widescreen DVavi.
    Feb 2002
    capture the DVavi
    I'm sorry, I don't know what this means.
    When I capture the footage, it looks as it does in the Canon camera -- with black bars on top and bottom AND stretched out the same way (horizontally).
    The only place it looks normal is on my television, as described above.
  5. make a small 5 mb sample and post it here, or use a file sharing site and post a link to a larger one.
