Hi everyone, i'm doing small research about wireless network. i want to test the quality of the channel in various different congestion level. i want to use "ping" command to introduce traffic to the network channel. would everyone please tell me what parameters i should use in ping, so that it introduces a quite big traffic to the network. thanks
Results 1 to 9 of 9
you know this is a video site, right?
anyway a ping is only 1 packet or 4bytes or 32 bits. how you send multiples is up to you. -
you can ping -l 65500 (actually 0 - 65500)Originally Posted by minidv2dvd
that's pinging jumbo packets of 65,500bytes
You can also trace route which is a better indication of congestion along the way to your distination
You can also use tools like ethereal or cacti -
Yeah, but I still use the older version when needed. Wireshark is limited to sniffing to only what come across the computer it's running on. Not good if you want to put your NIC into promiscuous mode to sniff all traffic
ping -t pings the specified host until stopped using Ctrl-C.Originally Posted by stiltman
Maybe you could do a ping -l 65500 -t <hostname> ?
Or do a ping/? to see other options.
If you want to introduce traffic, copy a couple of 100MB files across. Then you'll see congestion
If in doubt, Google it. -
I agree with sending the 100Mb files, this is a test which will yield useful, real-world results. Check your ping results while the file transfers are going on.
The Ping test is really more of a connectivity test than a real traffic analysis. Users do not know or care about Ping results, however transfer time for a large file is something they can get an immediate handle on.
I used to do a simple batch file loop to make a directory, copy test files, delete originals, and then reverse the process. Generates continous traffic with a simple visual record, brings the hard drive into the test also. -
Yes, but ping only shows you the time it takes to get to and from the distination. The traffic congestion may not even be at the destination, thus skewed results for congestion. Trace route will show you congestion along the way to and from the distination, thus a much better example of congestion
Samsung BD-C6500T fails Gateway Ping Test. Why?
By North43West80 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Mar 2011, 13:36 -
How do I introduce a picture in the frames of a film?
By Yogy in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2010, 23:44 -
RealNetworks to introduce a DVD Copier
By rcguy1 in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2008, 10:20 -
Traffic shaping on YouTube - is it happening elsewhere?
By Midzuki in forum Off topicReplies: 2Last Post: 20th Aug 2007, 19:03 -
severe interference on digital tv from traffic
By robotica71 in forum Newbie / General discussionsReplies: 5Last Post: 23rd May 2007, 05:24
