I have an AVI file which not only goes in and out of sync, but specifically, sounds such as car doors, gunshots, etc. appear in sync, yet the voices are out by maybe 300ms or so. Any ideas? Would SyncView help here?
you can't have it both ways. if some stuff is in sync and others not, it's just a badly done video.
I have downloaded several copies of this movie - from different sources and various sizes, and they all seem to have sync problems - some much worse than others. I believe they all used VBR though. Would it help a bit at least if i were to change the audio to CBR and remux? I'm fairly new at this, so please bear that in mind. thanks
Almost all AVI files (Xvid) files floating around with mp3 audio will be VBR. The bulk of them play and convert to DVD properly.
You could open your AVI in Avidemux. Leave Video at 'copy', under Audio choose AC3. Then File-> Save video. Add .avi to the name you choose. You'll now have CBR audio.
Which one is this app? AudioVideo Synch?
By CactusMan in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2012, 07:31 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
Live video streaming on windows media server 2003.. video/audio is not syn.
By edirector in forum Video Streaming DownloadingReplies: 1Last Post: 15th Jul 2008, 19:05 -
Sound out of syn and need recommendations on programs.
By PsychoPigeon in forum Newbie / General discussionsReplies: 9Last Post: 25th Dec 2007, 19:05 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10
