I have a couple X264 files that are 720p. I am trying to play them using VLC player. The CPU is only at 40 - 50% but I am getting occasional hitches in the playback every couple minutes. A freind of mine says you need something faster than 3.0 Mhz for HD. Is that my problem?
Another thing that is interesting is that I see ATSC and Clear QAM capture cards out there that say they need less than a 2.8 Mhz to work(below). Are they telling the truth?
http://3btech.net/hawihvatntqa.html
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3584100&SRC...gtCjCVRqCjCVRq
I have a similar system, and I can play back MP4 H.264, but MKV files choke.
This is on a P4 2.8Ghz/400FSB non-HT system.Want my help? Ask here! (not via PM!)
Try instead play using Media Player Classic together with a newer version of ffdshow or coreavc. It usually works better then VLC.
Going from amd 9850 to pentium 9550
By johns0 in forum ComputerReplies: 1Last Post: 23rd Sep 2008, 23:30 -
Pentium P4 SL7E2 = Northwood or Prescot ???
By blinky88 in forum ComputerReplies: 6Last Post: 4th Aug 2008, 14:26 -
Performace...Pentium D to Core 2 Duo
By ron spencer in forum ComputerReplies: 14Last Post: 31st Mar 2008, 17:42 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 11th Jan 2008, 23:58 -
GIGABYTE motherboard / Intel Pentium D 935
By thebirdf in forum ComputerReplies: 4Last Post: 2nd Nov 2007, 13:50
