On my Local Area Network, a Network Authorization scheme was recently implemented. Now, if I want to get on the internet, I have to first click on a small installed software on my computer called Ruijie Supplicant and then click Connect. The problem is, when I want to use a VPN, like Hotspot, about 15 seconds after I connect to the VPN, the Ruijie Supplicant pops up and I am kicked off the internet. See screenshot. My question is: Does anybody have any idea how I can get around this? If I click Connect at this point I can get back on the internet, but the VPN connection is lost. If I click Adapter (red circle), there will be listed any VPN's that I have installed such as TAP VPN Adapter or TAP-Win32 Adapter V9, but I cannot connect to the internet if any of these are chosen. I can only connect to the internet if Intel(R) Pro/100 VE Network Connection is chosen.
EDIT:
I know nothing about Ruijie Supplicant.
I once did the following for another reason, using openVPN software.
This was with a static IP address (192.168.1.201) on the Local Area Network (LAN)
Write down the TCP/IP addresses for the LAN Adapter, Gateway & DNS server.
Write down the subnet mask.
Bridge the LAN Adapter and the TAP-Win32 Adapter.
Change the new Bridge Adapter TCP/IP properties to the same addresses as you wrote down.
Log on to the LAN
Log on to the VPN
Perhaps this will help.
Using a Seedbox or VPN..what to choose...
By Moontrash in forum ComputerReplies: 2Last Post: 12th May 2011, 18:38 -
DRM authorization codes
By VirtualDoobMon in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Jul 2009, 12:55 -
VPN IP Addressing Question
By Soopafresh in forum ComputerReplies: 5Last Post: 22nd Apr 2009, 12:32 -
Looking for VPN (virtual Private network) other than Hotspot Shield
By jimdagys in forum ComputerReplies: 0Last Post: 11th Dec 2008, 02:44 -
Software to manage network
By Caple in forum ComputerReplies: 6Last Post: 18th Jul 2007, 19:49
