To whom this may interest:
http://kurtnoise.free.fr/index.php?dir=misc/&file=ffmpeg-0.5.7z
HTH!Code:FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --enable-gpl --enable-postproc --enable-swscale --enable-avfilt er --enable-avfilter-lavf --enable-pthreads --enable-avisynth --enable-libfaac - -enable-libfaad --enable-libmp3lame --enable-libspeex --enable-libtheora --enabl e-libvorbis --enable-libxvid --enable-libx264 --enable-memalign-hack libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.31. 0 / 52.31. 0 libavdevice 52. 1. 0 / 52. 1. 0 libavfilter 0. 4. 0 / 0. 4. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0 built on Mar 16 2009 16:09:18, gcc: 4.2.4 [Sherpya] FFmpeg 0.5 libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.31. 0 / 52.31. 0 libavdevice 52. 1. 0 / 52. 1. 0 libavfilter 0. 4. 0 / 0. 4. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0
Another mirror www.videohelp.com/download/ffmpeg-0.5.7z .
I can't encode a xvid with mp3 audio. The file seems to be corrupted.
Nothing can play it and MediaInfo doesn't see it as a valid video file.
I already had this problem with other recent versions. I'm running on AMD Athlon XP200+ with sse only.
What is version 0.5 supposed to mean? I'm used to SVN-rXXXXX -
That is the latest official release from ffmpeg.Originally Posted by Chris K
http://www.ffmpeg.org/
That ffmpeg build is apparently compiled by kurtnoise. He post alot at doom9. If you have problems with his compilation you should probably post a thread there as I don't think he visits videohelp much ...although I can't imagine whyOriginally Posted by www.ffmpeg.org
Donadagohvi (Cherokee for "Until we meet again") -
Ah, now I understand!Originally Posted by freebird73717
Seems to be nothing more then the latest SVN releases from others which also suffer on the same bugs.
Thanks for the info,
Chris. -
If you don't have a broadband connection, and/or
don't care about 50MB of technical info + "esoteric" source-code,
you can download only-the-damn-binary from:
http://au.geocities.com/rashojin_mizuki/pub/ffmpeg_0.5_.7z.zip
(yes, I did have to store the .7z file in a .ZIP archive,
because Geocities is stupid
Anyway: "unzip, unrar, enjoy"
FFMPEG - Windows vs Linux ?
By Klagar in forum Video ConversionReplies: 3Last Post: 14th Oct 2010, 11:32 -
C# .NET windows service and ffmpeg
By datemandar in forum ProgrammingReplies: 3Last Post: 23rd Jun 2010, 04:14 -
ffmpeg for 64 bit windows
By Cazz in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2008, 19:36 -
can FFMPEG output info from video?
By squadjot in forum Video ConversionReplies: 3Last Post: 13th Apr 2008, 18:32 -
ffmpeg only 50% CPU usage in Windows
By ChrisStanleyCCTV in forum Video ConversionReplies: 6Last Post: 12th Nov 2007, 17:38
