right lads just got a dvd drive & would like to copy dvd like you do
so what do i use where do i get it & how do i use it
apart from that im ok LOL
LATER T
It's too bad there is no "How To" section here on VCDHelp, with information on "DVD Rip"ing...
If you want guides on DVD Ripping, you should probably check out http://www.doom9.net
Regards.Michael Tam
w: Morsels of Evidence -
go to dvdripguides.com and follow his guide, he even has all the links to the software you will need, I have used his method for over 2 years and 300 rips and have not found anything better.
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
How to fix incorrect time? MKV rip displays as 14+ hrs long in all players
By elcoyoteloco in forum Video ConversionReplies: 2Last Post: 6th Feb 2011, 12:11 -
Help reset my expectations - how big the rip will be, time it takes to..
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2009, 13:10 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
