I'm doing this video that will be previewed on LCD TV, I don't know exact make, but it's 40" or something inches diagonal and it's a model from 2006...I honestly don't know the brand
Thing is, I'm editing a clip in AE
Settings are PAL D1 DV Widescreen preset, 720*576, PAR = D1 DV Pal widescreen 1,42
First question - is that LCD TV possibly square pixeled? Or should I do it like I'm doing it now, with 16:9 AR ?
And another thing - when I flip the PAR correction in AE, so the circle I'm drawing looks like circle not an egg, th quality is already...low...it looks like I resized a jpeg picture to bigger resolution...
why is that? My rendering is set to full...
What is the video going to be viewed? DVD? DV camcorder? Then you should leave it like it is. If you are going to use some HD player you can resize to a 16:9 frame size with square pixels.Originally Posted by Mylo
Because you are stretching a 720x576 image to 1024x576 to correct the AR.Originally Posted by Mylo
Dedicated Video conversion PC
By tonyaldr in forum Video ConversionReplies: 14Last Post: 15th Aug 2011, 00:08 -
Is it time for a new forum dedicated to 3d video?
By yoda313 in forum FeedbackReplies: 18Last Post: 10th Apr 2011, 11:51 -
CRT or LCD for Video Editing?
By VideoTechMan in forum EditingReplies: 4Last Post: 16th Mar 2010, 16:23 -
Capturing screen image to video - using dedicated card - what software ?
By ullteppe in forum Video Streaming DownloadingReplies: 10Last Post: 12th Oct 2008, 11:34 -
getting new PC: use onboard video or PCI-e dedicated video card?
By alandla in forum Newbie / General discussionsReplies: 18Last Post: 27th Feb 2008, 11:13
