Hi All, I got a task from work. The boss wants to hear what ppl said in the dvd clip on camera. It's too many back ground and wind noise. So what can I do? Is this a possible task or just Hollywood stuff?
Results 1 to 16 of 16
I'd have to have a clip to test with.
Thanks guy. Any suggestions on the softwares or hardwares to use. I only have a basic computer.
Try the latest "beta" version, the 1.3 series. The noise filters are much better in this than earlier versions.Originally Posted by guns1inger
See http://audacityteam.org/wiki/index.php?title=Noise_Removal -
I have a stupid question, How to import the sound clip off the DVD? or How to prepare the sound clip from DVD then import to audacity,.
I tried to play the DVD with the laptop PC and at the same time hit record button on AUdacity. I thought it was recording because the wave time line is moving. But after 2 hours, I listen to it, it was just the noise in my room. So I dont understand. I wasted almost 3 hours on that and got nothing.
Please advise. -
Originally Posted by sydneynewbie
If it's an non-commercial DVD (i.e., not encrypted), in Audacity do "file /open", go to the VIDEO_TS folder on the DVD, choose file type "All files" and open the relevant VOB file (there should be several, you can use a media player to find the right one).
Audacity will convert and import the audio. (This using Audacity 1.3.7, and having installed FFMPEG to import/export various file formats. See installing ffmpeg plugin)
Or you can open the VOB with media converters (again, for example, FFMPEG) , convert to WAVE and open that.
This is the hard way, preferable, and much faster, to import as above, but there is a selector box on the toolbar where you choose the input. I think "Stereo mix" should record what you hear on players. You obviously had "microphone" selected.Originally Posted by sydneynewbie
Thanks AL, I found out the hard way. Yhanks for your help. Now I am doing more experiments to get something out of it. Wish there is a magic button for that kind of things.
Have been playing the clip. But how can I undo the effect, if I didnt like the effect and want to return to original file. I dont want to close the file and reload again. How can I undo the last effect I tried?
I will try one more day. If not, I may post a clip here and see you experts can crack it for me.
But I w to try first. Is there any manual I can read about the application? So many terminlonogies I dont understand.
BTW, how to do a clip and paste here? -
Ok, I found the undo, trying again. But appreciate the way to upload clips to here.
haha, found the upload button just right underneath here. I will try that only when I am desperate.
Edit/undo, or control-Z. You can undo every action since you opened the file.Originally Posted by sydneynewbie
I usually just select a short passage to test an effect on, try it, undo, and when I get it right, apply it to the whole clip, or section.
Anyway, your effects are not saved unless you do a file/save (which saves it as an "Audacity project"; you have to export to get a normal wave/MP3/Ac3 or whatever format you want).
http://www.audacityteam.org/ has links to the manual, wiki and a forum.Originally Posted by sydneynewbie
The Wiki_Home_Page has a bunch of links to tutorials, tips and background info. Join the Audacity forum where the experts can help you.
Why do scifi bad guys never have security cameras and wear armor?
By yoda313 in forum Off topicReplies: 6Last Post: 10th Apr 2011, 15:44 -
All these choices...Security cameras
By jdigs in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2010, 17:32 -
Live video streaming, is it possible with security HDTV IP cameras?
By Woohooo in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2010, 16:58 -
Video cameras & airport security machines
By toxicquack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th Jun 2009, 03:18 -
Creating Clips effectively from large mpegs -- HDD Cameras
By bryan andrews in forum EditingReplies: 1Last Post: 22nd Jan 2009, 11:36
