  1. I am pretty new at this. I successfully ripped a DVD. After several steps I successfully burned a VCD which successfully plays on my wifes win2k system but hangs my system. My system is approx. 6 months older than my wife's. I can play DVDs, commercial VCDs, AVI files, and MPEG files BUT NOT my VCDs. Why????? Help!!!!
  2. have you tried copying the .dat file on to your hard drive?
  3. Haven't tried copying the .dat file to the HD. As I said the VCD plays fine on my wife's win2k system so I thing the .dat is fine.
  4. actually i had figured out the dat was fine(it plays on your wife's system) i was wondering about your cdrom. it might also help to know how you played the vcd (what software)
  5. Not a problem ... We both use CinePlay to play DVDs, etc. Works on my wifes system for VCDs but not mine. I have also tried QuickVCD - same result. The simple insertion of the VCD disk causesthe SW to hang on my system.
