Hi!
Excuse a perhaps strange question from a relative newbie...
Let me explain my problem:
I want to modify the sound level in a AVI file, using only DOS tools.
I have used FFMPEG.EXE to split the video and audio data apart - that works great (make separate AVI and MP3 files).
I have also modified the audio data (still the same length so it shall match, only volume changed with MP3GAIN.EXE dos program).
But!
Then comes my problem. How to join them back together.
I have found a tool called DIVXMUX.EXE that should (?) do the job but it just quits. I have tried on several videos with same result.
Is there any other way to do this in DOS, than by DIVXMUX.EXE ?
Can FFMPEG join them back together, just as nicely as it tore them apart?If so. What command line options? There are some many... ugh...
Please help!! Many thanks in advance.
It worked!! Thanks a million!!
I know what I did wrong.
I just assumed I could not provide the "-i" option more than once. IŽd tried placing filenames after eachother but that did not work... Obviously, it needs the -i in front of each of them.....
THANKS!!
No MS-DOS sound in Current set-up
By Frank-0-Video in forum ComputerReplies: 13Last Post: 9th Jun 2011, 09:16 -
Were Windows 95 and 98 true OS's even though they had dos integrated in em?
By yoda313 in forum ComputerReplies: 24Last Post: 1st Apr 2011, 16:49 -
MPEG1 -> MP3 conversion possible in DOS?
By Figge in forum Video ConversionReplies: 3Last Post: 25th Mar 2009, 09:05 -
Question about certain dos commands
By jimdagys in forum ComputerReplies: 35Last Post: 15th Oct 2008, 23:57 -
Capturing movie from MS-DOS screen mode
By gasumi in forum Capturing and VCRReplies: 3Last Post: 10th May 2008, 08:17
