I looked for the answer in the Newbie audio sync sticky and didn't find what I was looking for so here is my problem:
I have an AVI file that plays fine in VLC with no audio/video sync issues, however when I converted the AVI to DVD using AVI2DVD the resulting audio/video was out of sync. So I opened the AVI in Media-Info and under the audio tree it says Video delay: 500ms. Next I opened the AVI in AVI-Mux and corrected the 500ms delay to 0ms but the resulting AVI file was out of sync. What I want to know is how can I convert the AVI to DVD and still keep the 500ms video delay so that the DVD will be in sync, or how to make an Avi with no delay that is in sync. If a similar issue has been addressed somewhere else then please point me in the right direction.
Cheers.![]()
What did you expect? If a half second delay keeps it in synch, removing it will put it half a second out of synch. You want to apply that same delay to the DVD audio. One way to do that is to feed that out of synch AVI into AVI2DVD. That should then give you an in synch DVD. I think (since I don't use that program).Next I opened the AVI in AVI-Mux and corrected the 500ms delay to 0ms but the resulting AVI file was out of sync.
If the audio in the AVI is already AC3 audio, you can demux it and remove the delay with Delay Cut, before then remuxing it to feed into AVI2DVD. If it's MP3 audio, something like HeadAC3he can remove the delay. -
Since the original AVI was in synch, I'd suspect a variable bitrate MP3 as your audio source.
Take a look at it with Gspot and see what you find.
If that is indeed the case, demux the whole file, use one of the options above to make the audio constant bitrate AC3 and feed that into your authoring program for remuxing.
I personally use Adobe Audition to complete that task and save the audio out to 48000 wav. Then I let DVDLabPro transcode the audio during the authoring phase. Those are both "for pay" proggies, though and you might want a free solution. I'm not real familiar with some of those since I don't need them. A little experimentation will go a long way, but you get the jist of the workflow, right?
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 15:56 -
Question about which AVI type in Total Video Converter plays in DVD player
By jimdagys in forum Video ConversionReplies: 2Last Post: 22nd May 2008, 08:37 -
DVD video+AVI audio?
By uniks in forum AudioReplies: 8Last Post: 7th Mar 2008, 03:25 -
Legal Question regarding Copyrighted Audio on Video Photo DVD
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2008, 12:40 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
