Here I use ffmpeg convert Divx type into H264 ts, some like Mainconcept software function
But I found out it can't all most the same
My demond as
1.High bitrate with HD video contrant bitrate (8Mb birtate or 10Mb bitrate)using FFmpeg
2.H264 ts stream NTSC tv standard type and interlaced with Top First
command as below:
ffmpeg -y -i a_scanner_darkly.avi -vcodec libx264 -f mpegts -top 1 -r 29.97 -bufsize 2000k -b 8000k -minrate 8000k -maxrate 8000k -s 1280x720 -acode libmp3lame -ar 48000 -ab 224k a_scanner_darkly.mpg
problem 1:
Contrant bitrate is not working as document said
problem 2:
-top 1 for interlaced Top first field is not working,too
so I wonder ~ is the argument working on it?
Becuase I try Mainconcept is working well~
I need to use FFmpeg to instead of ~
Results 1 to 1 of 1
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 21:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
How to convert .h264 to .avi
By yonyz in forum Newbie / General discussionsReplies: 2Last Post: 4th Mar 2009, 15:48 -
How do you convert H264 to AVI ?
By Shadowofthedarkgod in forum Video ConversionReplies: 7Last Post: 25th Feb 2008, 19:01 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 13:52
