I have a movie in AVI format that I want to put on DVD using DVD Lab Pro. What tool should I use to convert it to MPEG-1 without losing its quality?
Thank you!
Results 1 to 9 of 9
If at first you don't succeed, call it version 1.0.
WHat are the specs of the AVI ?
Why Mpeg-1 ?
Mpeg-1 on DVD is restricted to VCD resolution and low bitrates. Unless your source is very poor, you will lose quality as VCD is an inherently quality limited solution.
If you want to create a DVD, I would use AVStoDVD to do the encoding, setting it to output elementary streams. These can be loaded as video and audio assets into DVD Lab Pro, and authored into a DVD.
If you really do want VCD resolution then I would use FAVC and select VCD resolution for the output and keep the working files. You can use these when it is done for authoring. FAVC will encode using mpeg-2 but give you better quality than standard VCD if the running time is not stupidly long.
Again though, it comes back to what your source is, and what you are trying to create.Read my blog here.
Actually, I just want to put the movie (900 MB) on dvd and add subtitles. For the past weeks, I've been reauthoring video files from VCDs to DVD using DVD Lab Pro and I haven't got a problem. Now that I have here an AVI file, I don't know what to do... I thought that converting it to MPEG-1 would cause me no problem like my VCD files.
Hmm.. I think I'll check out AVStoDVD since you said the output files can be loaded into DVD Lab Pro.
Thanks a lot, Guns1inger! I'll be back when the wheels got busted. Heh heh.If at first you don't succeed, call it version 1.0. -
VCD transfers across because the files are already DVD compliant. No re-encoding is necessary, so no quality is lost.
Your AVI file does have to be re-encoded, so quality loss is always a risk. 900MB tells me nothing of real value. The running time is more important. If this is a just a standard movie length file, then AVStoDVD can encode it to DVD compliance. Expect it to fill an entire disc when authored.
If you don't need a fancy menu (or a menu at all), AVStoDVD can in fact encode and author a disc, with subtitles, ready to burn.Read my blog here.
I tried AVStoDVD but I just can't tweak some preferences coz I dont know them... I'm afraid I might damage the file. I used Xilisoft Video Converter Ultimate and I guess it's more user-friendly than AVStoDVD.
Just one more thing... what's aspect ratio?
Read my blog here.
MPEG-1 on DVD allows up to 1856kbps, better than VCD. But it's still lackluster compared to 352x480 @ 2500kbps ("CVD/SVCD quality"), a 4-hour DVD. And even that can be pushing it depending on the MPEG encoder and the source material.
Best format to convert HD videos without losing quality?
By fabitos in forum Video ConversionReplies: 19Last Post: 4th Dec 2011, 00:22 -
MKV to AVI - can you convert without losing quality?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2010, 08:52 -
Want to convert from VOB to .mov without losing quality
By kleiber in forum MacReplies: 5Last Post: 14th Feb 2009, 08:00 -
How to convert MTS files without losing any quality whatsoever
By xucphra in forum Video ConversionReplies: 2Last Post: 7th Feb 2009, 10:44 -
How to convert AVI to MP4 using H.264 encoder without losing video quality
By VidHunter in forum MacReplies: 0Last Post: 21st Dec 2007, 02:04
