Results 1 to 20 of 20
    Mar 2009
    HI....WHO CAN TELL ME THE BEST WAY TO CLEAN A DVD???
    WHEN YOU SIMPLY NEED TO CLEAN A DVD OR CD UP A LITTLE WHAT IS THE BEST WAY TO CLEAN THE DISC OR DO I NEED TO LITERALLY FIND A PROFESSIONAL????
    I HAVE ONE OF THOSE DISC DOCTOR HAND HELD THINGS BUT THEY SEEM TO LEAVE A "PATTERN" THAT ENDS UP "DAMAGING" THE DVD EVEN MORE?
    EVEN THOUGH I USE THE LIQUID AND EVERYTHING!!!!
    VBOND0071@AOL.COM
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I rub them on my Levis.
    NOT kidding.
  3. Why is it that AOL users seem to be the worst at Netiquette
    http://en.wikipedia.org/wiki/Netiquette
    Originally Posted by jagabo
  4. Member bendixG15's Avatar
    Aug 2004
    -R or +R ?
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I run them through my dishwasher then dry in the microwave on high.
  6. Originally Posted by Noahtuck
    I found adding Jetdry to the dishwasher really does keep the spotting from happening. It has the sheeting action, so says their commercials
  7. Member Number Six's Avatar
    Mar 2008
    NOT kidding.
    hech54 - You will never be allowed to touch any of my DVDs :P
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
  8. I spit on it and then wipe with my cotton shirt.
    Just my 2 cents.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    NOT kidding.
    Even my son's backup DVDR's that he has fingered for a few minutes
    while he fumbles to remove it from my funky player can be easily cleaned
    with a foggy breath from the mouth and a wipe on the Levis.
    Factory pressed discs don't even require a foggy breath....just wipe
    them on the Levis and stick them in the machine.
    I can't even remember the last time I used anything else to clean
    a disc...and I can also not remember the last time I had a disc skip
    because it had a few smudges on it.
  10. Originally Posted by hech54
    This is so funny too.
    I do the exact same thing fogging with my breath.
    My son (5yrs old) thought I was licking them (he never asked or said anything)
    I get home one night and my wife asked me if I was licking our DVDs before putting them in the player. I said no but I breath on the dirty ones, and wiipe them on my shirt or pants. My wife goes, well your son thought you were licking them, and that's what he was doing today... I busted up laughing so hard
    Nov 2003
    Charlottesville, VA
    Hot breath and a cotton shirt. Been doing it that way with CDs and DVDs for years.
    Oh yeah, wipe from the center out.
    Aug 2006
    I usually run them under the tap, add a drop of dishwashing liquid, rub gently, rinse and dry with a terrycloth towel, wiping from the center out.
    I think I once rented a disc cleaned using the Levi's method. Only problem was they forgot to avoid the rivets.
  13. Banned
    Jun 2004
    That's what i do also, espc. when i rent, warm water & dishsoap, my bare fingers, rinse, shake off then pat dry.
    Shaking them usually takes the majority of water off.
  14. Member turk690's Avatar
    Jul 2003
    ON, Canada
    vbond0071, the disc doctor is for removing scratches that can't be wiped away with spit and a T-shirt. Used as instructed, they do leave radial patterns (which is not surprising since they actually sand the disc surface in the prescribed radial way, and whose appearance shouldn't bother you) but they do really make the disc playable again.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  15. to get out scratches on an unplayable DVD use an orbital sander with 1000 grit papper followed by 2000 or 3000 wet grit
  16. Member Number Six's Avatar
    Mar 2008
    Would that be a BINFORD 6100, by any chance
  17. Originally Posted by Number Six
    Not sure what the model number is, mine is an older model. However, looking at the Binford catalog, they do make the 6100 orbital sander
  18. Member Number Six's Avatar
    Mar 2008
  19. Member Ethlred's Avatar
    Feb 2008
    Because some people think all those without Netiquette are AOL users.
    Sure the OP gave an AOL email address. Perhaps its a clever disguise. Kind of like wearing glasses with eyebrows and a mustache.
    I use liquid detergent and water in a sink. Sometimes with discs from the library I do two passes before drying. A drop or so of detergent then work out from the center with my thumb. Thorough rinsing from the center, no fingers or thumb. I use cold water.
    Spin off most of the excess water on those occasions that there is a lot remaining. I use a screwdriver for the spin. Then I dab off the water.
    NEVER RUB when drying. Cotton would be good but I usually use toilet paper. Absolutely do not rub with paper of any kind. If its just a few drops you don't even have to touch the surface. Touch the drop and the paper will suck it. Unfortunately it rarely works out that nicely and dabbing is needed.
    Now if you have distilled water around a final rinse with that and air drying should do the trick nicely. I haven't tried that but it should work and then you wouldn't have to risk scratching with manual drying.
    Ethelred
  20. Just get one of these to repair discs. Only $1495.00!!!
    http://www.cdrepairman.com/onestep.php
    Although I must say that their article about scratches on the label side is BALONEY! For a pressed CD, a scratch on label-side, or torn label, should not affect the data. This is only valid for recordable media.
    http://www.cdrepairman.com/repair.php
