  1. Advise.... trying to prevent 5 yr old from messing it up
    Linda
  2. Load the relevant Template ( .mcf ) / file..... into notepad ( File Types: all files ) and change the settings you want to lockout by using the word 'TRUE'.... you'll see what I mean once you load the Template into Note pad..... once finished simply select 'SAVE'.... and NOT 'SAVE AS' ...... Job done 8)
    Paul. ( UK )
