Hi
I'm having some problems splitting movies. The video-codec is a divx. The audio-codec is AC3.
I'm using easy videosplitter and movavi video suite 6. Both are closing or crashing when I want to launch the split-process.
I maybe think it is the AC3-codec the problem. Both programs work fine when it's not an AC3-codec.
Anybody any idea. Or is there a different tool that supports AC3-codec when I want to split it.
thanks in advance
virtualdub (use direct stream copy for audio & video), or avidemux. You may need ac3acm if you use virtualdub, avidemux should have everything included
Problem splitting mkv files
By Sennaista in forum Video ConversionReplies: 8Last Post: 5th Jul 2012, 21:57 -
Problem Splitting MPEG and rejoining with mplex
By jon111 in forum Authoring (DVD)Replies: 6Last Post: 3rd Mar 2011, 21:13 -
Movica splitting problem
By bartman99 in forum EditingReplies: 0Last Post: 11th Jul 2010, 21:33 -
Splitting Track Problem in Vegas
By duderdude2 in forum EditingReplies: 2Last Post: 23rd Feb 2010, 15:55 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18
