finally got the CPU down to a respectable idle 45C with new heatsink fan (arctic cooler freezer 7 pro). and was wondering in the bios should Q Fan control be enabled and CPU Max set to say 70C? what exactly does this do? does it say hit 70C then the fan works harder to cool it and keep it at that max? or will the PC shutdown once it reaches that temp? i dont mind the noise if thats the only drawback to having Q Fan enabled.
reason im asking is because i was having CPU overheat issue where the temp would read 90-100C! finally after replacing 2 heatsinks (intel stock and arctic cooler 7) this one has brought the temps back down to what i think is normal for this P4 3.4 MHz Prescott.
there are a bunch of different q fan bios. yours may be the one with min med max settings? is so they were the temps that set the speed of the fan as in when it hits 70c the fan would be set to max rpm. shutdown temp is usually in a different section of the bios.
Bios malfuncitoning
By Illusionist in forum ComputerReplies: 1Last Post: 23rd Dec 2009, 19:25 -
BIOS version
By A Traveller in forum ComputerReplies: 2Last Post: 25th Oct 2009, 08:56 -
How ACCURATE are the readings on Speed Fan, they differ from those in BIOS
By blinky88 in forum ComputerReplies: 7Last Post: 20th May 2009, 15:17 -
Can't get to BIOS
By videocheez in forum ComputerReplies: 5Last Post: 31st Aug 2008, 21:23 -
ACPI in bios - on or off?
By kenmo in forum LinuxReplies: 1Last Post: 15th Apr 2008, 07:23
