Results 1 to 11 of 11
  1. I have tmpge and it is about to expire
    i know in the older version you could go in and edit the registry
    is that possible with this version?
    I am on windows XP
    the version i have is tmpgenc 2.5
    any suggestions would be appreciated it
    thanks
    BT
  2. The most foolproof way to do that is to ...... buy it.
    Feb 2002
    Oregon
    I would gladly purchase tmpgen but cannot fiqure out how. If I try clicking on the "Buy site" I get a blank page. Anyone else having this problem? Any help would be appreciated.
    Jim
  4. Originally Posted by Feuerwehr
    Jim
    I had the same problem. I am using IE 5.5 and by hitting the go button in the address bar on the blank page the page was displayed properly.
  5. The othe foolproof way is to do a SEARCH of the forum, and you will see hundreds of post where this same question has been posed & answered.
  6. Originally Posted by Kdiddy
    That is true but the patch does not work with V2.52.
  7. Go to Run in the start up menu and type in "regedit" And the go to HKEY_CLASSESS....\CLSID\ and delete {63902277-B101-4049-8B46-C24b....} that will reset the vali period. Or you can reinstall it I heard that that works. I use 2.5 and it works for me but I'm using Windows ME.
  8. Anyone have suggestions
    I have tried the crack and had no luck, because my version has now expired and I also looked in the registry for this key and could not locate it
    any help or suggestions would be appreciated
    BT
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    you buy tmpgenc plus, http://www.pegasys-inc.com/e_buyinfo.html
    discuss cracks/warez somewhere else please.
  10. this will work for most files http://www.cracks.am
  11. Baldrick
    It wont happen again
    I was under the impression that this was not against the rules, my bad
    I have tried purchasing it, but had some problems
    I will take these sort of questions elsewhere in the future
    BT
