    Mar 2009
    Thailand
    Hi,
    I just started using BD Rebuilder and all my movies are getting resized to 1920x1080p.
    How can I make sure the original size is maintained while using this software?
    Thanks,
    Gary
    Apr 2004
    Miskatonic U
    If your source is BluRay (which is what BD Rebuilder is for) then it is already 1920 x 1080p.
    What do you think your source is ?
    Read my blog here.
    Mar 2009
    Thailand
    Hi,
    The movies are downloaded from the Internet. Some are 720p and some are 1080p. When you look at the file information (MKV file),
    some of the sizes are 1920x816 (star Wars, for example), 1920x800 (Hitchhiker's Guide to the Galaxy), etc.
    I would like to maintain the the width,height and put them on a DVD9 disc, but BD Rebuilder keeps resizing them. I would have thought the program would read the input file and output the same width, height and aspect ratio.
    Any suggestions?
    Gary
    Just backup from you original blu-ray.
    Mar 2009
    Thailand
    Hello,
    I do not have the originals. As I said, I am downloading them from the Internet.
    Gary
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Before you dig the hole any deeper, you might try reading the forum rules . . . . . .
    Read my blog here.
