I have an audio recording in WAV format that was recorded directly off a soundboard.
My problem is it has an annoying "ungrounded buzz" thru-out the entire audio track.
What software can I use to reduce this buzz & still keep it in the WAV format? I'd prefer a freeware option if possible.
OK. thought i'd report back.
i tried Audacity's noise reduction. it sampled the "buzz" then removed that frequency thru-out the whole audio track. it made the voices of the muscial i'm putting together sound synthesized. a very odd sound. didnt like the results.
i then tried WAVPad. it removed the "buzz" during all the silent gaps in the audio track, but left the "buzz" whenever audio was present. the results sounded much better than Audacity's results. Even though there is still "buzz" its much less noticeable since you dont hear it during the silent gaps.
i guess this is pretty much as good as it gets without having to spend $$$ on a complex software package.
if anyone has any other thoughts, chime in..... -
I do not think there is much you can do about this, to not to affect rest of the audio, with any software.
You can try, if software you have will allow that, get that frequency range and not to remove it completely, just make it less loud.
constant buzz from earphones
By ecos in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2012, 19:43 -
HELP! Feedback buzz on some portions of video
By MrRoboto in forum EditingReplies: 1Last Post: 5th Jan 2011, 08:20 -
Audio replaced with buzz following encoding
By mycatsnameis in forum ffmpegX general discussionReplies: 9Last Post: 23rd Nov 2009, 19:45 -
cleaning up audio buzz?
By spiritgumm in forum AudioReplies: 1Last Post: 15th Apr 2008, 20:43 -
Removing Buzz in MP3
By ZeroX5 in forum AudioReplies: 16Last Post: 5th Jul 2007, 14:48
