I need a good capture card within $150 dollars or so for a good capture card that is region free, i already have a vhs player.
Although my vhs player is 10 years old, should i get a new one? if so could you recommend me a good one that you have good experience with that is around $100 dollars. This would be a real help!
Also i want to later look into cleaning up the video as the vhs cassettes are really old, so i fear they may have "artifacts" and such. Would i have to fix this with software or hardware, and before or after. Please keep in mind i can not afford the expensive 600 dollar system like the Canopus ADVC-300 that does it for you. Is there a cheap cost effective hardware method or software?
I have looked into this a lot, some people say that pinnacle and hauppage cards sometimes are not good at this, so i would like one that someone has good personal experience about.
Past that i am sure i will be able to convert the videos into dvd or such, i am sure software will be able to do such, i am very computer literate so it should be a problem. Please let me know if i am wrong here.
Also im not interested in a pal vhs to ntsc dvd recorder unless you know for it to perform really well and better than or comparable to pc in my price range.
In summary:
- a good capture card that you know performs well for its price (approx up to $150)
- do i need a new vhs reciever? if so recommend in $100 range.
- any video enhancing options? should i need hardware or software? (looking for really cheap cost effective hardware, i know it might not be possible)
You need to properly address the PAL VHS in an NTSC environment situation first. You say you "already have a vhs player". Is it a PAL VHS player?
yes it is a pal vhs player, but its about 10 years old, should i replace it?
i basically want the clearest quality conversion into ntsc format on my computer. I am sure that there are many ways of using the computer to convert to ntsc after, so i just want to get the vhs videos in the clearest possible quality onto my computer in about $200. -
Actually I MUCH prefer a hardware conversion between PAL<>NTSC over computer conversion.
BUT...since neither you nor I have the bucks for a decent hardware converter...your going to need a PAL format capture card for your computer....or one of those USB "things" that I have no experience with.
That tape better REALLY important (IE...not released to DVD) cause this can get expensive....especially for one tape. -
they are home videos i want to convert.
so i really need to get them done. I need a good suggestion for a card that people know works well, i have heard even the brand names sometime don't perform as well as a cheaper card. -
I personally chose a Hauppauge PVR-350. It encodes to MPEG2 "on the fly" to save wear and tear on the computer's processor.....so to speak. I bought mine used (Ebay) and it works perfectly....used it last night as a matter of fact. You can download all of the software and drivers directly from Hauppauge's website(in case you get a used one like me with no software disc)....and you can get them pretty damn cheap. You'll probably need to get yours from "over here" in PAL-Land.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Poor Video Image from PAL VHS Capture
By ww12345 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2011, 12:57 -
Recomended Software for fast simple compatible capture and conversion
By The Turtle in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2010, 15:10 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS capture to HDD
By bcags7 in forum Capturing and VCRReplies: 2Last Post: 17th Oct 2008, 13:59
