I've got a videotape that plays fine except at the bottom of the screen there is a band of distorted image. This band is probably only 10 lines thick. Other tapes play fine except this one. I've tried it on a few different VCRs and they all play it the same way. I've tried adjusting the tracking to no avail. Is there any other adjustments I can make or is the video cassette damaged/faulty. The picture quality is fine so I know its not dirty heads.
Any help appreciated
K109
Disregard my previous post. I didn't read the question well enough, it would seem.
This band is probably only 10 lines thick. -
Open the door of the cassette and look at the bottom edge of the tape - if it is rippled, then the tape is damaged beyond repair. This is a common failure caused by a faulty transport system in a machine that the tape was once played in - not necessarily the machine that you are using now.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Is the tape with the distortion a copy of another tape? If so, there is a slight distortion added to the bottom of the picture for every generation a VHS tape is copied. A Time Base Corrector may clear it up, but I'm not sure.
This can be a common problem especially if you play an older tape on a deck that was not the original recording deck. Most of the time this area is not large enough to be visible on a TV screen due to the overscan, but will be visible on a computer screen. If you are capturung the tape, you could post process and crop/mask the area using AviSynth.
I get this distortion on my tapes all the time. I found turning on the video stablizer option in my JVC menu solves the problem. But I prefer to use crop with AviSynth as the video stablizer can cause additional problems. -
Thanks for all the help. The tape looks OK (its not rippled). The tape is not recorded from another tape. I have looked into a time base corrector but in the UK they are astronomically expensive (£180-500+). So thats not an option. It looks like its some defect in the tape so I'll just crop the distorted lines. Thanks again.
K109
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
VCR Playback Problem
By Robert the Bruce in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2011, 07:05 -
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
Distorted color on playback?
By Nathan1 in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2008, 20:21 -
VCR playback
By Cosmas47 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2007, 00:51
