The How To for converting VIDEO_TS to DIVX instructions at one point say- "Select title/chapter/angle to be encoded as you require."
Forgive my noobiness, but are there any entry level info sites out there that will help me with what these settings exactly do, and how I can determine what I "require".
Thanks so much, great site, great app.
A DVD can have multiple titles (main feature, interview, making-of, etc.). On a low level these are numbered (title 1, title 2, title 3, etc).
A DVD title can be chaptered. This allows the viewer to jump to certain points in a title. Chapter markers are used in e.g. a "select a scene" menu, and can also be jumped to by repeated use of the [Next] button on a remote.
Some DVDs have more than one "angle" for some scenes on the timeline. This would be like showing a scene/clip based on a previous choice of an angle, while not showing the scene(s) that go with the other angle(s). Such a selection might be based on e.g. a language menu, or a decision to follow a certain character.
DivX is linear and does not have these features. So in order to convert DVD to DivX, one must decide what to include: Which title, which chapters, which angles.
Most often the main feature on a DVD is in title "1". Most often you would want to convert all chapters of that title (the whole movie). Most often there is only one angle. This is also what you would get with default settings in ffmpegX.
If you convert to DivX, then chapter information is not in the output, as that format doesn't have specification of chapters.
The two chapter fields may specify the starting chapter and the ending chapter for a conversion. It only has meaning when converting from DVD/VOB.
If you leave the chapter fields empty, then ffmpegX will interpret that as "all chapters".
If you fill in "1" and "10" in the chapter fields, then ffmpegX will convert chapter 1 through 10.
If you fill in "15" and "15" in the chapter fields, then ffmpegX will convert only chapter 15.
If you fill in "23" and "29" in the chapter fields for a DVD title with just 20 chapters, then ffmpegX will convert nothing.
The chapters are time markers on the DVD, as specified by its author. Chapter markers can be anywhere, e.g. one chapter per scene or group of scenes, or every 5 minutes, or only at the beginning of a title. The playing chapter number may be visible on the display of a set top DVD player (mine does).
Blu-Ray angle Info tool
By Oktober in forum Blu-ray RippingReplies: 7Last Post: 22nd Jul 2011, 05:07 -
Entry level camcorder for video blogging
By Arty84 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Feb 2011, 18:31 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16 -
Number of possible chapter entry points: 1 - WTF?
By DRP in forum VCDEasy GeneralReplies: 20Last Post: 20th Mar 2008, 18:50 -
Removing a chapter from a title
By GrayStrickland in forum EditingReplies: 2Last Post: 22nd Nov 2007, 01:52
