Results 1 to 15 of 15
    Feb 2002
    Dark Side of The Moon
    I am trying to make an SVCD with Nero. I can make them with any AVI so far, with no problems. I have a movie now that has subtitles (in a seperate files, an .idx file and a .sub file). Is it possible to make a VCD that will include the subtitles?
    Thanks in advance!
  2. There is a guide at
    http://www.vcdhelp.com/svcdsubs.htm
    HTH
    /Wintermute
  3. I can't get/find I-Author and the 'SVCD selectable' subtitles don't work for me. However, the 'CVD Selectable' subtitles do.
    I would d/load the demos of both types under the 'what is' section to the left to see if your DVD supports it. If not you'll have to make permanant subtitles (which is very easy to do).
    Feb 2002
    Vejita-sama (or anyone) : Is there a way you know to make the subtitles permanent on an AVI so I can just burn that to an SVCD?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    one method is to use virtualdub with the subtitle filter
    http://www.vcdhelp.com/srtsubsvirtual.htm
    Feb 2002
    Baldrick - Yeah I was trying that, but for some reason the SRT to SSa coverter won't recognize my .sub file as a valid subtitle file
  7. Best method for CVD subtitles:
    Rip all the subtitles using Subrip0.95a (i think that is the correct version).
    Encode, multiplex, and split your mpeg files.
    Add the subtitles using submux.exe to your mpeg files.
    Create bin/cue files using VCDEasy (latest version).
    Burn and enjoy your subtitles
    Let me know if you need more detailed help.
    Feb 2002
    warthawg - Ok, here's what is going on:
    I have an AVI of a french film. It has the subtitles to it in a .sub file. If I play the AVI in PowerDVDXP, it looks and sounds great with the subtitles as well. I need to get them all onto a SVCD. The subtitles are in a .sub format.
  9. You need the subtool23 to convert the .sub file to .srt. If u want I can send it to you.
  10. Hey, warthawg, where can I find that submux.exe and in which format the subtitles must be???
    Feb 2002
    hunting - I have that, but whenever i try to open the sub file it tells me that it is an usupported format
    I know the sub file works though, I watch the AVI with subtitles all the time, and it's the only subtitle file I have
  12. That's strange. Have you already tried to convert on SubSync?
    Feb 2002
    Yeah it just keeps giving me that error!
  14. Originally Posted by warthawg
    I have my subtitle in SRT and in SUB i canīt get SUBMUX to work. is there any guide somewere. Can you explain what i need to do?
    Tanks
  15. I'm not sure what the etiquette for posting links for I-Author, since it says you shouldnt post warez links, but even VCDHelp says to use it. Anyways, I've found a link for I-Author. Umm..email me or go to google and search for "i-author". It should be within the first 20 hits. Its actually a forum post on afterdawn pointing to the actual page.
