I am just trying to learn the nuances of avisynth and decided to try out something using virtualDubMod.
I wrote a small script in avisynth to normalize a small file containing a song.
The file was a size 87 MB, with a length of 5:16 min.
Now when I load my script file in virtualDubMod, and save it as .avi with option "Direct Stream Copy" it produces a file of size 2.5 GB for this small song file.
Here is my script file.
clip=AVISource("trial_video.avi", False)
aud=WAVSource("trial_audio.wav")
aud=normalize(aud,0.95)
AudioDub(clip,aud)
ResampleAudio(48000)
This is more from a learning perspective. I was trying out the audio options of avisynth.
Is there any place where I could set the video bit rate. Seems the encoded bit rate with virtualDubMod is very high.
Moreover in QuEnc encoder things work just fine in terms of expected file size since I set the bit rate to around 2000.
Can someone let me know how bit rates are set in virtualDubMod ?
But I would like to process my video without any encoding.
My intent is to first demux the audio (already done).
Make some changes to the audio stream, remux with video and then save the file.
In fact I want the virtualDubMod not to do any video processing. -
use virtualdub instead, as it allows you to "use audio from other file"
But as midzuki says using avs script will give you uncompressed (i.e. whenever you use avs script, you have to re-encode). So open the original AVI file directly without avs script:
video=>direct stream copy
audio=> direct stream copy, audio from other file (point to your new audio, normalized in another application - e.g. eac3to) -
In that case you can't use Avisynth. It creates a virtual AVI file with no compression and gives that to VirtualDub or whatever you use that opens the AVS file.Originally Posted by pranab31
help with virtualdubmod
By losernoob in forum SubtitleReplies: 7Last Post: 12th Sep 2011, 10:23 -
What should I use instead of VirtualDubMod?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 02:06 -
AviSynth with VirtualDubMod - Inverse Telecine advice needed
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 7th Dec 2010, 01:29 -
Audio missing when opening an Avisynth script in WMP & VirtualDubMOD
By aln688 in forum Video ConversionReplies: 3Last Post: 2nd Apr 2010, 05:09 -
BD to AviSynth (Or VirtualDub/VirtualDubMod) ???
By RogerTango in forum Blu-ray RippingReplies: 4Last Post: 3rd Jan 2009, 08:31
