Hi All,
I'm looking for a way to convert 16-bit 44,100 hz or 48000 hz wave or flac files to lpcm [so I can make some Audio only DVD's]
Please note, I need lpcm not pcm
Any software suggestions, preferably freeware?
TIA
What is the authoring tool you intend to use ?I'm looking for a way to convert 16-bit 44,100 hz or 48000 hz wave or flac files to lpcm [so I can make some Audio only DVD's]
The only difference between uncompressed .WAVs and (L)PCM files
is the RIFF header/container, plus the inverted byte-order.
DVD-lab Pro for example happily accepts 48kHz uncompressed .WAVs.
Audacity should be able to resample 44.1kHz to 48kHz and
save the result as a "raw" LPCM stream, if that's what you really need.
Hi Midzuki
Updated Info: I deleted my lplex folder and copied over a fresh version - now lplex is accepting my 16/24 bit 48kHz wav or flac files
I am using the opensource lplex application
http://audioplex.sourceforge.net/
I have used this before just using 16-bit 48kHz wav or flac files - but now I am getting an error message indicating that audio files are not "lpcm"
I was able to use eac3to to convert a 16-bit 48kHz wav to 16-bit 48kHz flac and lplex accepted it
I have also used Audio DVD Creator and Apollo Audio DVDMaker [I think it has been discontinued] - I do know that these two applications internally converted wav/pcm to lpcm - as this format is necessary to make a compliant DVD . . .
I have made several audio only dvds that give me 6 hours of lossless music - I have even used ac3 at 192 kbit and put 10 albums onto one CD that played on my DVDplayer, my MPEG4 player and of course, on my computer
Thanks -
eac3to input.flac output.lpcm -resampleTo48000Originally Posted by wiseant
as I mentioned earlier you may or may not have to use pcm2tsmu depending on your other software, because the header information in the lpcm from eac3to is slightly different -
Hello,
I'm trying to convert 5.1 Flac to 5.1 LPCM for streaming it to my DLNA-compliant BD Player, which doesn't support Flac playback, but supports LPCM over LAN - not sure if multichannel LPCM will be playable via its 7.1 analog RCA Out. I tried latest eac3to base package for this by running command:
which results in a file not playable on any player supporting LPCM playback like Daum PotPlayer or VLC.
What I'm doing wrong, and how to approach this task? What other players can play multichannel LPCM? What media info tool can ID media correctly for multichannel LPCM?Last edited by zamar27; 1st Jun 2012 at 13:36.
Convert DTS-HD to Flac
By SeeManRun in forum AudioReplies: 10Last Post: 25th May 2013, 20:46 -
How to convert .BUP and .IFO to AIFF, AU, FLAC, M4A, OGG Vorbis or WAV
By MLK3329 in forum Video ConversionReplies: 6Last Post: 5th Oct 2010, 21:13 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
use eac3to to convert 5.1 FLAC to 5.1 AC3 in MKV
By jntaylor63 in forum AudioReplies: 1Last Post: 3rd Mar 2010, 15:11 -
DVD to FLAC/SHN/WAV?
By Salva Veritate in forum DVD RippingReplies: 1Last Post: 26th Sep 2007, 23:56
