Hi all,
I am wondering if there is some sort of setting/filter/plugin/tool to link a layer onto another layer. For example, let's say i have a logo and i want that on a passing truck. I could be changing every frame manually but i have a feeling this can be done a lot better and especially easier. I am sure there isn't something magic since you have to keep track of perspective, speed, size, etc. but i guess there should be something..
Thanks in advance.
Normally you would do this in After Effects with the corner tracker, and use the data from that to pin your object to the corners on the video. As for Premiere plugins . . . Boris Red has a corner tracker, Red Giant has a filter called Warp that does corner pinning.
Read my blog here.
MST3K video layers
By krg765 in forum EditingReplies: 3Last Post: 29th Feb 2012, 08:29 -
Hidden Layers in Film
By Snuffy in forum Newbie / General discussionsReplies: 16Last Post: 18th Dec 2010, 10:30 -
Adobe Premiere updating layers?
By daiweb in forum EditingReplies: 8Last Post: 26th May 2009, 09:38 -
burning double layers
By macbaren in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2007, 04:50 -
Using certain layers of a video?
By bmcgonag in forum MacReplies: 3Last Post: 9th Oct 2007, 20:35
