So I was wondering are Wave form audio files the same thing as pcm audio files for dvd authoring? And I suppose now the same for Bluray authoring?
Also was WAV a Microsoft creation or was this created by some conglomerate like jpeg (joint picture expert group) and mpeg?
I know that you can use 48khz wav to make a standard dvd without using dolby digital or mp2 audio. I also know that pcm audio is very common on concert dvds to produce high quality stereo tracks in addition to 5.1 dolby. So is there any difference between a stereo wav dvd track you make yourself and a professional pcm audio track on something like a concert dvd? Obviously the source material will be the main difference. But technically speaking are they same thing?
WAV is a container like AVI. It can contain uncompressed (PCM) audio as well as audio compressed with any audio codec.
WAV is an MS spec. -
@jagabo - ah thanks. That was something I did not know about wav.
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48 -
PCM audio on BluRay
By ecc in forum AudioReplies: 2Last Post: 21st Jan 2010, 09:37 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
