Hi
I have good quality footage from a PAL HI 8 video tape. I capture it as PAL DV.
When I convert it to NTSC MPG2, the footage is slightly jerky, mainly on scenes such as
panning or zooming in and out.
I use Pro coder 1.5 to do the conversion. The bit rate is around 7000.
Can anybody recommend another application that will do PAL to NTSC seamlessly.
I have no problems going the other way NTSC to PAL.
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
Using the encoder of your choice encode the video as ntsc resolution 352x240, 352x480, or 720x480 with pal framerate of 25fps. Then apply dgpulldown 25->29.97 to that elementary video stream. Output will be an ntsc elementary video stream. Author with that stream and original audio.
Donadagohvi (Cherokee for "Until we meet again") -
Your PAL source is interlaced (or at least it should be).
freebird73717's information is wrong for interlaced footage.
Follow this guide: http://www.digitalfaq.com/guides/video/convert-pal-ntsc.htm
Procoder conversion will be craptastic. Good encoder, lackluster formats converter.Want my help? Ask here! (not via PM!)
You didn't say why you want to do this.
PAL plays OK to a PC or certain DVD players.
Software conversion to NTSC is difficult and disappointing,Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
That was the first thing i thought also, It was because of not being deinterlaced.Originally Posted by lordsmurf
But then i thought about it and it could be jerkiness from an incorrect frame rate conversion also.
Which is why i always use TMPGEnc over anything else for PAL to NTSC conversions.
Once again, for the 1000th time this week, just a guess from lack of useful information....
6 years, 56 post's and obviously minimal reading or searching....
60fps versus 50fps? PAL or NTSC in AVCHD?? need advice!
By ftitus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th Nov 2010, 07:11 -
Not sure if it belongs here but need some advice on PAL/NTSC conversion
By HmNtr in forum DVD RippingReplies: 16Last Post: 29th Aug 2010, 11:48 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 14:15 -
FAVC 1.04..Please Advice..Every time I convert PAL to NTSC
By sandman423 in forum Video ConversionReplies: 6Last Post: 3rd Jan 2008, 22:21 -
hardware solutions to PAL/NTSC conversions
By JakeAy in forum Video ConversionReplies: 8Last Post: 19th Aug 2007, 12:26
