I burned some video files on a DVD, just as data files, not an Authored DVD.
They play fine when they're on my Hard Drive, but when I'm playing them from the disc, they LOOK good, but the audio is skippy/choppy.
This is the DVD drive I'm using:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106229
I'm on 2.8ghz Pentium 4, Windows XP, using Media Player Classic. I had the same problem with Windows Media Player.
Even when I copy the videos OFF the DVD to my hard drive, they play fine on the hard drive!
What do I do? Any suggestions would be greatly appreciated!
Results 1 to 9 of 9
What sort of audio do the files have ?
I know that my Pioneer has problems like this playing back AC3 audio from an AVI container. It does not have any problems if the audio is MP3, or if the AC3 is in the DVD structure. My other players happily play AC3 audio in an AVI container.Read my blog here.
Its happening with a variety of videos. All dvdrips. xvid with mp3 or ac3 audio. Its not a codec issue, its more of a speed issue or something. The audio gets choppy when the computer is trying to play videos when its doing a bunch of other memory intensive things. What is the problem here? Please tell me anything I can do about it?
Don't do all the other "memory intensive things" that you are doing that that makes your videos play poorly.Originally Posted by Xenogear900
Your question is basically the same as saying that your leg hurts when you hit it with a hammer, and asking how can I stop it hurting. The answer is to stop hitting yourself with the hammer.Read my blog here.
Nooo, I'm saying that it also happens when doing memory intensive things. It happens even when I'm not running anything other than the video.
try another media player, KmPlayer from http://www.kmplayer.com/forums/ is a good free one
Remux the audio and video -- one frame of video, one frame worth of audio. Burn to a new DVD. Better?
As Gunslinger pointed out, it's possible your drive isn't using DMA mode. It's also possible you are using low quality media, or a media the Lite-On is having trouble reading.
On a side note, is the video also choppy?Google is your Friend
Help with burned DVD's skipping
By BDrums1971 in forum Newbie / General discussionsReplies: 20Last Post: 1st Sep 2013, 16:06 -
BD-C6900 cannot play BD-RE 25GB data disc
By mineownus in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Dec 2011, 12:15 -
Distorted Cracky Audio with burned music videos
By DatBoyYank in forum Newbie / General discussionsReplies: 6Last Post: 10th Aug 2007, 02:25 -
will a avi data disc play in a divx player?
By nobbyiscool in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2007, 15:23 -
avi files burned to dvd skipping...any idea why
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 8th Jul 2007, 03:10
