See Subject. They probably are no longer available from retailers, but did one like that exist and any idea where I can get one?
Results 1 to 20 of 20
That's not a mini-cartridge tape, if I understand the abbrevation.
??? HDV is shot on miniDV tape. the sony HDR-HC9 can record either 1440x1080 HDV or 720x480 SD. there is no other consumer cam tape.
It's not an abbrreviation...it's the model
HC1, HC3, HC5, HC7, HC9...all mini-DV tape drives
Of these, the HC1 had the most features... -
(This may be a duplicate post. I just hit postreply and don't see my post 30+ minutes later. I suspect I should hit Quick Reply. Here' goes.)
I was unaware of these camcorders, so let me refocus what I'm after. No high-def, and cheaper. I'm looking for something like the older TRV-480 that I have. -
whats your budget?
I bought the Canon HV20 for $499 refurb(now $429 I think)it shoots in both DV,and HDV
TRV480 is Hi8 not miniDv -
Yes, I know that. I have one. What I need is a cheap way to get to a hot shoe.
I would think the next step up from it would be mini-dv with a hot shoe. -
the one i listed is the only current sony minidv tape based cam with a hot shoe.
What would be of interest is knowing what Handycam came after my TRV above. Interestinly, for the first time, I recently started looking at CL.ist.
Are you sure "hot shoe" is standardized and not brand specific?Originally Posted by solarblast
I don't recall any hot shoe models promoting support for other than their own brand accessories. Will a Canon hotshoe mic work with Sony or visa versa?
Hmmm. Reminds me I have a Sony hot shoe active mic and a Canon HV20. I'll try to find that mic.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I guess I think I'm implying by hot shoe that it has the ability to put a mike rcvr on the shoe and plug it into the camcorder. Basically, I'm looking for an early model that will use a mike remotely. I want the ability to have a mike remotely. I'm trying to keep the cost under $300 by buying an early model, if possible.
I mostly use wireless remote mics. Camera mounted mics are less successful unless inside 10 feet.Originally Posted by solarblast
Back in the early 90's I bought one of these to do a friends wedding. OK for the money. It doesn't use the hot shoe.
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=3659&Q=&is=REG&A=details
For serious work I rent a Shure or Sennheiser wireless mic system.Recommends: Kiva.org - Loans that change lives.
Thanks, but no camcorder under $300 with external hook-up, then I the device isn't going to help me.
Old Sony Handycam to PC
By cincy_kid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jul 2011, 00:05 -
Want to Upgrade my Sony Handycam
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 9th Jun 2011, 11:34 -
Sony camcorder shoe question
By PDX Ghost Hunter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Nov 2010, 04:01 -
Hot shoe pinout
By danno78 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Mar 2009, 12:19 -
Camcorder advice : Tapeless, Mick jack, Low light, Hot shoe.
By adumi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Nov 2008, 00:28
