hi im newbie here ,seek guidance from you guys here.I have an animation project file,that already done in Pal format.The problems here is I need to sent for client reviewing and he wants it in NTSC format.So how can i do it?heard about pull dowm etc...mind to share...thanks..
Assuming this PAL video is progressive 25fps, there are 2 main ways to do the conversion:
1. Resize to 720x480, keep the framerate at 25fps when reencoding, keep the audio length unchanged, and apply DGPulldown for 25->29.97fps.
2. Resize to 720x480, change the framerate to 23.976fps by reencoding to 23.976fps (after slowing the video and not by dropping a frame every second), and apply standard 3:2 pulldown afterwards, and slowing/lengthening the audio as well.
If the PAL source video is interlaced, either deinterlace it and then follow steps one or two, or use AVISynth to add duplicate fields properly to bring the framerate up to interlaced 29.97fps and do a proper resize to 720x480.
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 17:34 -
29.97fps subs to a 25fps Video?
By solrage in forum Authoring (DVD)Replies: 34Last Post: 1st Feb 2011, 22:16 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 10:45 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 15:29 -
avi is 23.97fps,srt is 25fps
By Soixante in forum SubtitleReplies: 7Last Post: 3rd Dec 2008, 15:26
